Synology - Some Folders Not Showing, Some Do
Server Version#: DSM 7.1.1 - 42962
Player Version#: 1.29.2.6364
Hi All,
Plex noob here who is trying to play his music library via Alexa as the DS Audio skill is a underwhelming.
When adding my ‘shares’ to library, only the photo works as they rest are empty (but they are not) The only work around is to select the USB back up which is fine for photos but its not big enough to bak up other media. I just use it for the more important things,
The shares are set up identical and were all done at the same time about 10 years or more ago.
PHOTO FOLDER - Works OK as you can see the sub folders
TV SHOWS FOLDER - Plex cannot see the sub folders
OK, sorted, When I updated to the latest Plex a very helpful box told me I need to change the permission drop down box to internal user and grant plex read/write on all the shares.
