System is defaulting to /sdcard
when i try to add a new media library, the system is defaulting to location /sdcard. and when i try to manually enter a location like e drive or F drive nothing happens . any help?
If you click the “Add Folder” button, this should bring up a dialog where you can pick the folder you want to add. No need to manually enter anything.
Edit: If you’re not seeing that… could you share a screenshot of what you get to see when you click Add Folder?
