TerraMaster Library files empty
Server Version#:1.41.0.8229
Player Version#:n/a
TerraMaster F4-424 TOS Version 6.0.500
OK here is everything I’ve tried to get Plex working again.
I uninstalled latest Plex update .8229 and went back to the base from the Application list on TOS. Which I know was working fine.
Cleared out all configuration files in the Plex folder.
Moved all the folders back into plex library folder.
I can see all the data in the folders on my desktop, my phone, everywhere and can even watch it via media players, so I know the data is good.
For some reason when I try to add libraries I go to /volume1/plex/library/movies click add and Plex says the library is empty.
If it’s a permission thing I have gave access in every location I can think of. But you would think if it was that I wouldn’t be able to access the data on other computers.
Plex Media Server Logs_2024-09-20_16-51-15.zip (290.2 KB)
Just an update.
It has now been confirmed that there is an issue with permissions in the latest release of TOS 6. So this most definitely not a plex issue.
