text lyrics
I have made txt files of lyrics and have put them in the same folder as the flac songs but have been unable to get them to show. I have Local Media Assets check for both Artists and Albums what am I missing. Thanks
Is the filename, excluding the extension, exactly the same as the flac file? This is necessary.
If not, rename the lyric file to match the music file exactly (except the extension), then refresh the album. When you play the track, you should have lyrics.
Did you name the file the same as the song file?
Yes it is named the same
Is the LyricFind agent enabled in Settings > Server > Agents?
file:///home/ken/Multimedia/Pictures/Screenshots/Selection_351.jpg
If that’s all correct, I can’t think what else would be stopping it.
I got it to work. Thanks so much.
