The connection is not strong enough to play this video
Can you not just tell me that.
The best Plex server with the stronges, the best and fastest cpu there have so many cores as possible.
Plex was testing me because I need a better cpu. But i cannot give my bærbar computer another cpu, because this is a mobile cpu. So therefore a dedicated Plex server where there stands Plex Will Be the best. i Can Play some of my movies without problems. But not all.
Sure buddy, i’ll help you out. The best and festest cpu with the most cores is atm the AMD Epyc 7763 with 64cores.
But that a dedicated Plex server? And how do I set Plex up on it so Plex does not run on my computer but on it? How it works. I know nothing. explain it to me.
You should explain what the best Plex server with the best, fastest and strongest with af fastest, the best and the stronges cpu with so many cores as possible. A plex server.
And it has to be very very cheap.
How cheap?
Very cheap. Sometingwith 600 crowns or something with 1000. But not something with 2000 or higher.
Im waiting for an answer
I really need help with that now
Im waiting
Is that the best Plex server with the fastest, strongest and the best cpu with so Many cores as possible?
I suppose you’ll be waiting for a long time based on how you ask and develop your question to demands.
You’re asking for the best, most powerful CPU that must also be cheap… that’s usually conflicting requirements – then you’re moving on asking for an entire system and assistance in setting it up.
Please keep in mind this is a public forum. Users will try to answer your questions if they can but not because you demand it every few minutes. Pushing other users around will get this thread locked.
As pointed out in some of the earlier replies… there’s no correct answer to your question. Some users are perfectly ok with a Raspberry Pi, others go with a Mini-PC, others need a super-powerful machine that can deliver multiple parallel streams. Some might even be happy with a NAS as the one you have linked above (however that particular model is no longer supported by the manufacturer).
That’s very different solutions for very different use cases.
There is no such thing as some magical “best” server. If you are considering a NAS I highly suggest you read this to understand the benefits and limitations of running on a NAS Category : NAS Devices | Plex Support
Also the logs you provided from server and iOS were from two different times. After playback fails need the get both the player logs and the server logs immediately so both have the information from the same attempted playback event.
Also you need to stop replying to yourself like this every couple of minutes. You are not helping yourself getting anyone answer you faster.
But I answer and write all the time and say I am waiting for an answer because I want it solved and because I am mentally handicapped and mentally handicapped. It’s just frustrating that I can not get to know what’s the best and all that. I have been told that I have been told that my connection to the server is not fast enough to stream this movie, check your network or select a lower playback quality because my cpu is not good enough on my computer and that is true. So therefore I need a dedicated Plex server with the best, fastest and strongest cpu. and it must be very cheap because I do not have that much money.
and the cpu should have as many cores as possible.
Why is my post hidden? I just told why I did it. So Can you not Respect me?
Why is what post hidden? nothing was removed
I asked you to play something and after it you get the error to provide the logs from the server and the player. Are you going to do that?
