Based on the information you shared there’s nothing obvious pointing to a bug/error.
It might be some hiccup in the process, not enough time for the server maintenance…
And what is that problem? No enough time? What do you mean? But when do there come all these pictures. I tried to delete all three films of the hobbit and i too them after that back to my library. And only in one the hobbit film came pictures. So there are no issues or what with my server or in my server or both or with my account or in my accont or both or with these films?
Go to Settings → Server_Name → Library
Set Generate chapter thumbnails = as a scheduled task and when media is added
If it is already set that way, leave it alone.
If you made any changes, select Save Changes.
Go to Settings → Server_Name → Scheduled Tasks
Set start time to 0:00
Set stop time to 23:00
Check all same boxes as in the picture
Save changes
If you have not already done so, make the directories E:\PlexDance and F:\PlexDance.
If Warcraft: The Beginning is on E:, move it to E:\PlexDance.
If Warcraft: The Beginning is on F:, move it to F:\PlexDance.
Return Warcraft: The Beginning to its original location.
Scan the library if Plex does not do so automatically.
Wait.
Leave Plex Media Server running for 48 hours.
Do not power the server off. Do not stop the Plex Media Server processes.
This will give Plex Media Server time to scan your libraries and generate chapter thumbnails.
The CPU utilization may be high during this time. That is normal.
But there too many. That is too much because there are too many. I will not do a plex dance. This is too much. And where should that’s maps being placed. And I’m asking again. And what is that problem? No enough time? What do you mean? But when do there come all these pictures. I tried to delete all three films of the hobbit and i too them after that back to my library. And only in one the hobbit film came pictures. So there are no issues or what with my server or in my server or both or with my account or in my accont or both or with these films?
And now plex told me again that the connection is not fast enough to stream this video. Why does it say that? It should be an error with the account or my server. I hate all this. What should I do? I have the strongest internet I can get and ethernet cable.
You can keep the same temporary folder to “park” the movie folders when doing the Plex Dance. You can also move all movie folders from your actual library folder at once into the temporary folder. As long as the temporary folder is outside the library folder you’re good to go.
But why would there come these pictures before? Is there a bug in my account or with my account or both or in my server og with my server or both or with my server and i my server and with my account and in my account? Is there a bug or more bugs?
