The Daily Show Meta Data Incorrect
Whenever I record the Daily Show, it tags it with the incorrect season several years old. Any way to fix this?
I suppose you’re trying to record episodes of THIS show but get them mapped as ones of THAT one?
If you cannot correct the mapping when scheduling the recording (can you? I haven’t yet started to use DVR), you could fix-match the show afterwards or fix the file names by specifying which one it is (e.g. by including the year it first aired).
Ya, I know I can fix it after. Trying to find a way to fix it so it records correctly.
I don’t think you can… where you can usually adjust the file names to meet Plex’ media preparation / naming conventions, for DVR you’ll depend on the quality of show names provided by the EPG.
