Server Version#: 1.13.9.5456
QNAP 673
i have not been able to get a green remote gtg for several weeks. today i followed the suggestions of
turn on upnp in the router, (since the beginning it was port fwd setting) verify it is working by looking at the plex connection
locally log out of the cloud (then it shows unclaimed)
log out of the plex.tv
log out of the local
turn off local PMS
restart local pms
log into local pms
reclaim server address
log into plex.tv
the local pms shows green status
but remote clients, and the plex.tv pop up with the does not allow secure connections.
if i enable one time non secure, it works.
what am i missing?Plex Media Server.log (287.0 KB)
A couple of us have exactly the same problem , losing lock sign, can’t use https with same error message as the title of this post.
It’s weird that we all suddenly have the same problem at the same timing which is from yesterday and today impactibg multiple OS.
"type": "log:message",
"level": 1,
"message": "[Connections] Aborting connection test for NAS0DE9E0 at http://10.1.2.65:32400/media/providers due to mixed content prevention",
"time": "2018-11-07T20:50:39.957Z"
“type”: “log:message”,
“level”: 1,
“message”: “[Connections] Aborting connection test for NAS0DE9E0 at http://5xxx7:14497/media/providers due to mixed content prevention”,
“time”: “2018-11-07T20:50:39.958Z”
“level”: 1,
“message”: “[Connections] All connections to NAS0DE9E0 failed”,
“time”: “2018-11-07T20:50:40.929Z”
“level”: 4,
“message”: “[Servers] Found all servers = plex.tv”,
“time”: “2018-11-07T20:50:40.930Z”
“level”: 1,
“time”: “2018-11-07T20:50:40.936Z”
Ok, a fix has been made on our back end. Restart PMS and try again. This may take some time to propagate so if you still don’t get a certificate, try again a little later.
Thanks Peter, I ended up uninstalling the current version PlexMediaServer_1.14.0.5465-425e4ac90_x86_64 and reinstalling the previous version PlexMediaServer_1.13.9.5456-ecd600442_x86_64.
It immediately fixed the problem. Not the ideal solution for some I know…but at least it works
