On Linux, PMS will stop and restart.
I don’t know the details for all platforms from memory.
It’s always best to:
- Stop Plex
- Update
- Start Plex
Oh, I didn’t read that as an update was going to be released. Understood now, and thanks for all the hard work!!!
Did the plexinc/pms-docker container automaticaly build ? how long it’s take
All good for me too on 1.18.2.2058. Thanks for the hard work.
Yeah, still not working for me, updated to 1.18.2.2058, restarted the daemon, no dice Chicago…
Please gather the logs and create a new thread.
Before doing so, I will ask: Did you “Refresh All Metadata” ?
Update 1.18.2.2058
posters work
title and describe in french, not working
Exemple :
https://thetvdb.com/series/the-dragon-prince
In my plex :
Describe is not in french, yet the text in French exists
I started with each show, just so as to not flood the site with unnecessary requests. Just did a “refresh all…”, awaiting results
Can’t help with French in this thread. Don’t know where or what that is.
I’m trying to get Posters working.
I’m not getting anything. No posters and no text either
I am still testing 2058 .
Give me a moment please.
If it helps, my ‘com.plexapp.agents.thetvdb.log’ file is flooded with:
“(content type ‘image/jpeg’ not cacheable in Agent plug-ins)”
Ignore.
Please give me a few minutes. I’m using the same package all of you have now
Let me find out if there was a change since I tested it.
do you mean to the beta 1.18.2.2058?
Working for me on QNAP now
@ChuckPa thanks for your patience handling all the messages and solving the problem this week ![]()
Anyone know a good hair transplant specialist?
off topic - v 1.18.2.2058 has resulted in my having 0 folders in one of my libraries. They are there, because all my media is still showing there - but I cannot “see” the existing folders and the advanced tab is greyed out. Only asking in case @ChuckPa has a quick fix before I raise this as its own thread. Other libraries seem fine.
