This is a tips post and hopefully will help someone.
Plex Media Server Version#: 1.15.4.993
Plex Player Version#: Plex Home Theatre 1.4.2.100 (from QNAP App Center)
QNAP HD Station version#: 3.2.10
Issue:
- The video is fast forwarded and no audio when DTS audio is selected using Plex Home Theatre on QNAP TS-453Be inside HD Station
- When DTS is not selected, the audio works, but only PCM 2.0
- Audio output device shows “PulseAudio” and you cannot see your audio receiver (onkyo / denon)
Steps:
- Enable SSH on the server
- Login to the server through SSH
- Get the Plex_Media_Server install path
(for me, it returns “/share/CACHEDEV1_DATA/.qpkg/Plex_Home_Theater”)
getcfg -f /etc/config/qpkg.conf Plex_Home_Theater Install_path
- Go to that folder and edit
startup_Plex_Home_Theater.sh
- Add the following in the last line:
export AE_ENGINE=SOFT
- Restart Plex Home Theater application
- Go to settings > Audio Output > Audio Output device
Change the correct HDMI port (you can also see your correct receiver)
