Plex has been missing Live tv, and discover for weeks, My Pinned server also disappeared. The Search has become horrible too!
Since I dont have discover, I also Cant find friends.
On all Platforms!
On all Platforms!
Do you have them disabled for your account? The settings are at https://app.plex.tv/desktop/#!/settings/online-media-sources
You appear to have a very large number of servers folks gave you access to so would need to know which one is the one you pinned. Possibly it is offline or something.
It isnt the servers though.
I used to have a pinned one,
Along with discover, Livetv, and Plex Movies, all disappeared!
Along with the search gone retarded and doesnt show all the quarries as they used to.
Again, this has nothing to do with the servers and Everything to do with Plex.
Damn,
I didnt see this first!
They Were Disabled!!
I didnt even know you could do that!!
Who Tf Disabled Them!!
They Have Never Been Disabled In My Life!!!
Thanks For the Quick Reply,
Everything is Back to Normal.
Thank You!
But the Search still sucks!!
Many Strange old Movies and shows I used to be able to find, are gone, missing, the search is out of whack. I dont have the slightest clue what caused this.
There are some options there,
That I dont know how to leave.
It gives me disabled, or disabled for managed accounts. I left it for Managed accounts.
I have No Idea what else to put.
I Have every single Option there Checked!
Is the search bar settings enabled for “More Ways to Watch” setting for movies you don’t have to appear in search. You can see that in my screenshot. if you can give me an example of something you expected to find in search when you put something in the field I can try to help figure out why you might not be seeing it.
the movies with my server name are the ones on my server the other are just random things i never heard of which appear because more ways to watch is checked
Disabled means noone has the option.
Disabled for Managed accounts means it is enabled for the Home admin but not managed accounts.
some features Managed accounts cannot use at all that is why some don’t have an “enabled” option.
Since you don’t seem to have Plex Home set up then you want them to be either enabled or disabled for managed account
All of that was already set.
For some weird odd reason, all of a sudden the search is now working.
What do you mean I dont have a Plex Home?
You can use it if you want but does not look like you have enabled. It is so you can switch users in the apps. It isn’t necessary if you are the only one that uses Plex in your household.
https://support.plex.tv/articles/categories/features/plex-home/
If you have Netflix, or Disney+, you might know that you can have separate profiles under one account, for different watched history or recommendations. Plex Home is similar to Netflix’s user profiles. Those other accounts/profiles in Plex are called “Managed Users”.
I understand now,
And no. No other user, Plus,
I dont use disney or Net. I Got Plex to Leave Net, and it’s a Million times Better, cant think of a reason why anybody would use Net.
Plex is the Future, and will Easily Defeat Net.
