Trailer Adding for TV Shows/Series
Hi Together, is it possible to add a Trailer to a TV Show like in the Movie section? In the Movie section i tryed, very easy and works fine. But if i add a Trailer to a TV Show it doesnt work for me. I don’t see the Trailer on the Web Interface. I added it for example…
/4 Blocks
/Trailers
Trailer 1.mkv
Seems to be working fine. Are you using the Plex TV Series agent?
https://support.plex.tv/articles/local-files-for-tv-show-trailers-and-extras/
Yes i’ve checked. Plex TV Series Agent is used for the TV Show Librarie.
If it’s a single trailer, Plex might “collapse” / hide it and only display the film roll button indicating a trailer. Have you checked that?
So i tryed something. If i have a TV Show with only one Season and the Structure is like the example downwards everything is fine and i see the film roll button to start the trailer.
/4 Blocks
/S01E01.mkv
/S01E02.mkv
/Trailers
Trailer 1.mkv
But if i have a TV Show with a structure like this i don’t see the film roll to start the Trailer
/4 Blocks
/Season 1
//S01E01.mkv
//S01E02.mkv
/Trailers
Trailer 1.mkv
