Hello Guys!
Thanks for a very good and informative forum. I am running a computer with UBUNTU 14.04
I have an Apple TV (latest version both hardware and firmware) that is causing my already short hair to fall off even faster & more. I am soon bald!
The reason for this is simply " Whatever i do , i still get the message "Trailer is unavailable. Please try again later" message when pressing the Trailers app in my Apple TV.
I have tried nearly everything. I have read forum topics, guides, videos from 2013 , but nothing seams to help me.
Her is what i have done.
Created the SERTIFICATE FILES (trailers.cer - trailers.key - trailers.pem)
Installed the PLEXCONNECT
git clone https://github.com/iBaa/PlexConnect.git
Placed the 3 certificate files inside the folder /home/robert/PlexConnect/assets/certificates
Also added the 192.168.1.94/trailers.cer inside my APPLE TV - MENU - Send Data To APPLE play button procedure.
Then:
sudo ./PlexConnect.py
This resulting in PLEXCONNECT running fine. Then tried to open the Trailers APP on my Apple TV. resulting in, guess what? Trailers is unavaible. Please try again later
What am I doing wrong?
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3 & 7.0.3 6917
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.94
The local IP address of the device that PlexConnect is installed on: 192.168.1.94
The device and operating system (including version number) that PlexConnect is installed on: PC & UBUNTU 14.04
The device and operating system (including version number) that the Plex media server (PMS) is installed on: PC & UBUNTU 14.04
The Plex media server (PMS) version number you are running (do not put 'latest'):
Version 2.3.15The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.94
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork. Version: 0.5-dev
The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c) See Below
Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space):
A detailed description of the issue (the clearer you can make this the better):
Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one:
- shutdown PlexConnect
- in 'Settings.cfg', set loglevel to "High" (note the capital 'H')
- delete the existing log file
- restart PlexConnect
- repeat the issue
- immediately close PlexConnect and post the log.
- in 'Settings.cfg', set the loglevel back to "Normal"
[PlexConnect] enable_plexgdm = True ip_pms = 192.168.178.10 port_pms = 32400 enable_dnsserver = True port_dnsserver = 53 ip_dnsmaster = 8.8.8.8 prevent_atv_update = True enable_plexconnect_autodetect = True ip_plexconnect = 0.0.0.0 hosttointercept = trailers.apple.com port_webserver = 80 enable_webserver_ssl = True port_ssl = 443 certfile = ./assets/certificates/trailers.pem allow_gzip_atv = False allow_gzip_pmslocal = False allow_gzip_pmsremote = True loglevel = High logpath = .
Here is the output from the Terminal. Please ignore the attached PlexConnect.log (i uploaded wrong)
root@Server:/home/robert/PlexConnect# sudo ./PlexConnect.py
20:40:04 PlexConnect: ***
20:40:04 PlexConnect: PlexConnect
20:40:04 PlexConnect: Press CTRL-C to shut down.
20:40:04 PlexConnect: started: 20:40:04
20:40:04 PlexConnect: Version: 0.5-dev
20:40:04 PlexConnect: Python: 2.7.6 (default, Mar 22 2014, 22:59:56)
[GCC 4.8.2]
20:40:04 PlexConnect: Host OS: linux2
20:40:04 PlexConnect: PILBackgrounds: Is PIL installed? True
20:40:04 PlexConnect: IP_self: 192.168.1.94
20:40:04 DNSServer: started: 20:40:04
20:40:04 DNSServer: ***
20:40:04 DNSServer: DNSServer: Serving DNS on 192.168.1.94 port 53.
20:40:04 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.94
20:40:04 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:40:04 DNSServer: forward other to higher level DNS: 8.8.8.8
20:40:04 WebServer: started: 20:40:04
20:40:04 WebServer: ***
20:40:04 WebServer: WebServer: Serving HTTP on 192.168.1.94 port 80.
20:40:04 WebServer: WebServer: Serving HTTPS on 192.168.1.94 port 443.
20:41:23 DNSServer: DNS request received!
20:41:23 DNSServer: Source: ('192.168.1.123', 59966)
20:41:23 DNSServer: Domain: trailers.apple.com
20:41:23 DNSServer: ***intercept request
20:41:23 DNSServer: -> DNS response: 192.168.1.94
