Trailers really slow
When i open the trailers app it goes really slow and says accessing trailers. When i finally get to the tv show after about 5 minutes of waiting when it starts to buffer it kicks me off the trailers app.
Your ATV model: Apple tv 3
The DNS server set on the ATV:  192.168.1.3
The local IP address of the device that PlexConnect is installed on: 192.168.1.3
The device and operating system (including version number) that PlexConnect is installed on: Windows 8.1
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Windows 8.1
The Plex media server (PMS) version number you are running (do not put ‘latest'): 0.9.11.7
The local IP address of the device that the Plex media server is installed on: 192.168.1.3
The PlexConnect version number: Downloaded last month
The contents of your 'Settings.cfg' file:
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = Normal
logpath = .
Log File:
22:18:17 PlexConnect: started: 22:18:17
22:18:17 PlexConnect: Version: 0.5-dev
22:18:17 PlexConnect: Python: 2.7.9 (default, Dec 10 2014, 12:24:55) [MSC v.1500 32 bit (Intel)]
22:18:17 PlexConnect: Host OS: win32
22:18:17 PlexConnect: PILBackgrounds: Is PIL installed? False
22:18:17 PlexConnect: IP_self: 192.168.1.3
22:18:18 DNSServer: started: 22:18:18
22:18:18 DNSServer: ***
22:18:18 DNSServer: DNSServer: Serving DNS on 192.168.1.3 port 53.
22:18:18 WebServer: started: 22:18:18
22:18:18 WebServer: ***
22:18:18 WebServer: WebServer: Serving HTTP on 192.168.1.3 port 80.
22:18:18 WebServer: WebServer: Serving HTTPS on 192.168.1.3 port 443.
22:20:07 PlexAPI: ***
22:20:07 PlexAPI: looking up Plex Media Server
22:20:08 PlexAPI: GDM: Servers discovered: 1
22:20:08 PlexAPI: Servers (local, plex.tv, MyPlex): 2
22:24:40 PlexConnect: Shutting down.
22:24:40 WebServer: Shutting down (HTTPS).
22:24:41 WebServer: Shutting down (HTTP).
22:24:41 DNSServer: Shutting down.
22:24:41 PlexConnect: shutdown
Right this is happening again. Exactly the same but it spins on accessing trailers.
Any advice?
This is really annoying now as no one responded the first time of posting and i cannot watch anything!!
just got this
Geo location? Try to set your Settings.cfg to you ISP DNS then reboot PlexConnect. Also might be a good idea to update to the latest version of PlexConnect. Are you using iBaa's default github or a theme? Also a log set to high would be better as per the instructions in here:
click here
Also upload to pastebin or somewhere else then paste the linked log URL back here.
Typically this type of problems has been caused by having (this is not an extensive list):
  1. the ATV and/or PlexConnect and/or PMS in different subnets
  2. several python/PlexConnect instances running in the same same PC (for example one "as a service" and another "manually started")
  3. Users changing the PlexConnect code (in principle users should only modify Settings.cfg)
  4. Users having several VM's in the same PC with incorrect parametrization
In a "simple environment" PlexConnect should not show this type of problems.
