Hi
I bought a new PC and since then ( or maybe pure coincidence ) I have been unable to transfer a 4K movie to my iPad nor watch for more than 30 mins a movie without a failure.
“Conversion failed. The transcoder exited due to an error” - occurs during playback but nothing obvious during conversion when syncing.
Happy to provide log files but not sure how to … apologies.
Thanks in advance.Plex Media Server Logs_2018-07-23_21-32-22.zip (2.2 MB)
I have added the log file.
I have also updated to latest Win 10 version following other comments around this topic
I am having the same error. Started the day after newest update.
Tested and failed again.
Read your other thread and this has never worked on clean new PC. Yesterday I wiped old PC and getting same issue now.
Any thoughts suggestions on this - clean build PC failing on every 4K movie
sa2000
August 1, 2018, 11:25am
6
Does the issue arise also when hardware acceleration is disabled for the transcoder?
Just tried again with Hardware acceleration disabled and same issue
“The transcoder was unable to process this media.”
Tried 3 more movies and same issue.
Is there anything that can done on this or at this stage should I be looking at alternate solutions ?
What I have and have done to test;
PC1
Win 10 1803 17134.191
Intel Core i7 8700
Memory 32GB
NVidia GeForce GTX1070
Windows Updates
July 24, 2018—KB4340917 (OS Build 17134.191)
July 16, 2018—KB4345421 (OS Build 17134.167)
July 10, 2018—KB4338819 (OS Build 17134.165)
PMS 1.13.5.5291
5 Moves all 4K
All failed with Hardware Transcoding Enabled and Disabled.
PC2 - Clean Build 2 weeks ago.
Win 10 Pro 1803 17134.191
Intel Core i7-3770 CPU
NVIDIA GeForce GTX 660
Windows Updates
Both are connected to USB3 External Storage.
At this stage I’m almost ready to start using Handbrake and iTunes.Plex Media (2.3 MB)
I’d appreciate any ideas at this stage
EDIT
Just notice this thread and all content is TRUEHD
Hi.
Since a few weeks, I started to sync on my ipad video. 75% of video that contains TrueHD 5.1 and 7.1 audio failed. In stream, work very well.
I will do several tests and add the logs each time. Thanks for reply.
Rampage (2018)
Well I figured it out in the end … if I delete the TRUEHD audio track I can sync.
So either downgrade and I can be mobile or keep as is and can get best experience on home video/audio.
I can stream fine on iPad TRUEHD content so I’d have to call this a bug.
sa2000
August 6, 2018, 5:37am
10
An issue has just been discovered with the transcoder and TrueHD where there is a memory leak - it could be that but I would exoec5 to see references to memory allocation failures in the logs - do the logs you added cover a test with hardware acceleration disabled ? There may be separate issues affecting hardware and software transcoding
Plex Media Server Logs_2018-08-06_12-35-14.zip (2.6 MB)
New Log files attached with same movie HW Enabled and Disabled this morning 6/8/18
sa2000
September 6, 2018, 2:43pm
12
Plex Media Server beta 1.13.7.5369 has just been released. It has the fix for Transcoder memory leak.
See Release Note Plex Media Server
(Transcoder) The transcoder’s memory consumption increased over time on Android or when decoding certain audio codecs (#8830 ) (#8814 )
[Users with the early development build fix for windows should uninstall that version and replace with the new beta release]
The release may not be immediately visible on Google Play
system
Closed
December 5, 2018, 2:43pm
13
