VOBSUB Transcode Scrambling Video
Server Version#: 1.18.1.2019
Web Player Version#: 4.8.3
macOS Plex App Version#: 1.4.0.924-60046db9
My PMS is running on a Synology DSM918+. Whenever I attempt to play a video with vobsub subtitles, the transcode appears to be corrupting the video. This occurs on all web browsers and when chromecasting to a Samsung TV (and using the Samsung Plex App itself).
Without subtitle enabled:
With subtitle enabled:
Yet when playing on the macOS Plex App, the subtitles transcode correctly:
Anyone have any idea what’s going on? I’d prefer to play video on the TV than either convert the vobsubs or watch on a laptop.
Work around while resolving the Intel driver problem given
Thanks a lot for the quick response. That workaround works perfectly. Are there any performance disadvantages or similar to using the default driver in the meantime?
Only disadvantage of remaining with the older, stable, proven, i965 driver on ApolloLake CPUs (Synology) is at the extreme upper end of bit rates (100 Mbps+ )
