Transcoder Problem with subtitle
I have trouble with thai subtile in plex media server (Window 7 Ver. 0.9.8.18.290, Ubuntu Ver. 0.9.8.18.290, QNAP Ver. 0.9.8.10.215). Subtile show square character for thai character.
I have already post this problem in Qnap forum but now I think this problem is not relate to OS
https://forums.plex.tv/topic/87702-cant-display-asian-character-in-subtitle/?p=580711
I already try :
  • Convert SSA subtile to UTF-8 (with and without BOM) using subtitle edit or textwranger or notepad++
  • Convert SRT subtile to UTF-8 (with and without BOM) using subtitle edit or textwranger or notepad++
  • Install Plex Media server on window, ubuntu, qnap. To check that this problem is not OS Level. Window have thai font and correctly display in other app.
  • SRT and SSA can display thai character on VLC. I run VLC on window with PMS.
  • Install SRT2UTF-8. I already check log that SRT2UTF-8 working but can't fix problem.
  • For PMS in window, I change "Language in non-unicode program" to thai but this setting is not effect problem
I think the problem relate to transcoder. so if anyone have any idea how transcoder choose font for display subtitle or anything that relate to this problem that would be great.
Thank you
I found solution from this topic [HACK] Better Subtitles on All Devices - Custom Font + Japanese, Asian
Solution:
  1. Download Arial Unicode MS (search by google) or other font that contain thai character
  2. Go to /PlexMediaServer/Resources depends on what OS you are using
  3. Backup DejaVuUniversal fonts
  4. Replace DejaVuUniversal.tff with Arial Unicode MS
