Troubleshooting Remote Access
Version#:1.16.6.1592
I have spent several hours trying to configure Plex for remote access. My problem is that when I click on enable remote access, I get the message " Fully accessible outside your network" for approximately ten (10) seconds. After 10 seconds, I get the message “Not available outside your network”. I have tried to connect both manually and automatically. In both cases , the same thing happens. I even disabled my anti-virus program and my ad blocker program. I get the same result. I have a Verizon router.
Can someone explain what is happening? Or provide guidance to help me troubleshoot the issue.
Thanks,
Bob
It’s hard to know what’s happening (and I’m no expert), but here’s a guide for troubleshooting remote access:
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
Did you setup a port forwarding?
Check canyouseeme.org once setup for success on 32400.
Are you behind a NAT function from your ISP side? If you are you might have to buy a static IP address.
