TV Show Season Not Showing Up
I noticed that that the episodes in my children’s TV Show directory were not matched correctly because they did not follow the Plex naming convention. I fixed that and now the episodes for all the kids shows are shown correctly but the entire Season 2 for Blue’s Clues has now disappeared. I’ve tried the Plex Dance a few times, turned my computer off and on but no luck. I can’t figure out what else to do to get it back.
Looks like the episodes are named incorrectly for the Season & Episode labels.
The first one is E02S01 and should be S02E01 instead.
Looks like you swapped the "E"pisode and the "S"eason
I’d correct these and then Plex Dance that season.
I can’t believe I missed that. Thanks! It’s fixed now.
