TV Shows Display/Navigation Question
i have a quick question about how plex handles my TV shows as it stands right now TV shows display in the library like this now…
Show Poster - Season Posters - Episodes
i was wondering if there was a way to make it skip the season poster selection if there is only 1 season available and go directly into that season??
Show Poster - Episodes (since there is only 1 season in the library anyways)
There is
Go to: TV Library 3 dots>Click Edit>Advanced>
Scroll down, and you should see something that says “Seasons” and it currently says “Show” you can “Hide for Single Seasons” or “Hide” which will hide all seasons
yes thank you,
i actually just figured this out but it is exactly what i wanted to do thanks!!
