I have some TV episodes that show up as movies. They are in a separate TV Shows folder and it will be a later season also. Naming scheme is correct. Is there a way to force something to show as a TV Show?
Maybe give us some examples with screenshots?
Also… how have you organized your libraries inside Plex, at which folders are they pointing?
- /share/MultiMedia/TV Shows/Marvel’s WHIH Newsfront/Season 2/Marvel’s WHIH Newsfront - S02.mp4 is the path. Season 1 episode comes up in TV Shows as it should. Season 2 episode comes in as a movie
adding “E01” took care of it. since only 1 episode in the season it didn’t occur to me right away. thanks for your help
