what is the difference between a TV Show and a Movie?
I ask as I am importing my DVD library into Plex. I have the Gilligan’s Island and Classic Beverly Hillbillies on DVD. The Gilligan’s Island DVDs are imported as Movies, with single file per disk, with each file containing several episodes. Plex seems to recognize them fine. I have 18 episodes of the Beverly Hillbillies, have imported them as Movies, and Plex only recognizes 33% the files (6 out of 18). When I attempt to import either of these as TV Shows, Plex does recognize them at all - no files found of said type, or some such message upon library creation.
Any ideas as to why this may be happening, and what I can do to fix it? Does this have to do with my file system structure? I wouldn’t think so, but not sure of anything at this point. Also, I have just added the HD HomeRum Prime - which requires a TV Show library to store DVR recordings. Again, not sure what impact that would have.
is there a specific log file or setting - my settings/Plex configuration are default from installation, I should be looking at for clues?
Also, worth note, I have imported about 100 movies, and likely 500+ Music CD’s without any issue whatsoever.
Thanks for any insight you can provide.
