Twin Peak (2017)
Sabrina Teenage Witch
and
Sabrina The Animated Series
These titles are not found in plex agent.
Twin Peak (2017)
and
Plex Documentation → Your Media → Naming & Organizing Your TV Show Files
Make sure you follow Plex naming and organization requirements.
Plex Dance the show if you rename/reorganize to remove incorrect metadata from the Plex database.
Note that Twin Peaks 2017 is listed at TheTVDB.com as Season 3 of the original show. Organize your files accordingly. See Twin Peaks.
Since the update only Plex agent is available. I do not have TVDB. Twin Peak 2017 and Sabrina is not on Plex DB.
My system is using the Plex TV Series scanner and agent. See screenshot below.
The Plex TV Series scanner uses The Movie Database and TheTVDB information on episode ordering.
Please show how you have your files named and organized, including file extension.
Plex is very picky with TV shows. Follow Plex requirements as outlined in the documentation linked in my prior reply.
Plex Dance the entire show after any renaming/reorganization.
Since upgrading to the faster agent, there only one agent to pick from, ie plex agent. No TVDB or MovieDB like in the old system.
Correct, however you can configure the library to use episode ordering from tvdb or tmdb. It’s under the advanced settings of the library itself and NOT done through matching like with the legacy agent.
In the old system, if no match found I’ll use TVDB or MovieDB to find a match. The new system only have one agent to select.
No it will not. If plex does not find a show based off the naming you have on your files and you need to fix match you can search via the id for the show. So using The Munsters as an example you can search in the fix match box using tvdb-77280 or tmdb-1712. Both will find it, I just tested.
The new agent consolidates from multiple sources. There is no tvdb or tmdb or imdb agent. The new agent matches and then you can configure in the advanced settings which episode ordering you want.
The title box. But do check what the id is on tvdb or tmdb beforehand.
Also, there is NO Twin Peaks 2017. The episodes from 2017 are season 3 of the show.
