Two HDHomeRun Connect Duo with two antenna EPG not adding OTA channels
I have two HDHomeRun CONNECTs and two separate antennae to face different directions for the best signal reception of the specific channels. I am forced to add them consecutively after configuring the channel list on each device to be exclusive for that channel for optimal reception. Plex, however, does not add the newly available channels to the EPG when adding the second device even though they are both pulling from the same database, Over the Air.
I am trying to deconfigure the HD Home run to at least list all the channels for the guide and will disable the channels after adding the device to Plex to at least fetch the guide in its entirety and hope Plex picks the correct tuner for the channel.
Is there any tips or tricks until this is improved in Plex? Is it on the slate for Plex to improve this functionality to do such a simple thing? (Sorry to sound frustrated/disappointed)
I’m running a Wintv-quadhd along with an hdhomerun. In Plex on the first side of the quad it scans 27 channels the second side scans 23 and the homerun pulls in 33.
I have 27 local the extra 6 are duplicate relays from outlying areas. I edit those out then hit the continue and it loads it all up… Well it use to before the guide started to have issues. I would think the software would find a tunner that has the channel selected to record automatically
I would lean toward the issue you are having is with the guide and not the hardware
