Hello, I’m curious if Plex can manage two HDHomeRuns each with its own antenna and different channel lineups?
I have 2 different HDHomeRuns (The Extend and The Quattro) but I only use one antenna. Since in my area you are relegated to the 3 Service towers all in the same direction. I’m curious on where you live that has the ability for one antenna to be able to capture selective signals that the other antenna wouldn’t also pick up? How would you differentiate the EPG for such a thing?
Short and simple answer - yes it can. A friend has two separate antennas and two separate HDHRs. How it is configured, i am not sure. But it works.
I am North of Atlanta and there are towers to the North and South within range. I figured maybe I could disable the weaker channels per HDHomerun and let the stronger channels through if Plex could manage that it would be nice.
In Plex you can disable any channels that you don’t want to be available.
Sweet. No luck for me in the north of PA.
