Ubuntu Server 20.04LTS no HW transcoding available?
710d32a4-148a-f1b7-1bd06f23-4d4177d2.zip (52.7 KB)
@ChuckPa
Are these good enough? :slight_smile:
Can I PM you the pms logs?
Tried some test without Hw transcoding enabled, server runs fine without problems.
Enabling it - crashes the server.
Direct streaming works perfectly
@Morphy
Would you give this a shot?
@ChuckPa
I rolled back to Ubuntu server 20.04LTS 5.4.0-71-generic
The Ubuntu Desktop with the new kernel was crashing too often.
So far my plex server is running on the standard install (without hw transcoding ofc) .
Will this work the new .deb from you :slight_smile: ?
And how to I download in ssh for this Googledrive link?
@Morphy
when in a ssh, use wget URL (Linux 101 stuff :wink: )
This DEB file is the most widely reported “stable” version for all those folks with these newer processors
Regarding 5.8.0. If 5.8.0 is unstable, you need get that resolved. 5.4.0 will NOT be sufficient.
@ChuckPa
ahah funny :wink: - well I do know the Linux 101 :wink: wget curl… etc.
But when I rightclick your file and wget the link I just get a jiberish content download
Well I had 5.11 on ubuntu desktop after the upgrade , that one didnt work out that good ( with Desktop ) - now reinstalled and running Ubuntu Server 20.04 LTS.
hold on my last.
https://artifacts.plex.tv/plex-media-server-stable/1.22.0.4163-d8c4875dd/debian/plexmediaserver_1.22.0.4163-d8c4875dd_amd64.deb
Nah found a script :slight_smile:
#!/bin/bash
# Get files from Google Drive
# $1 = file ID
# $2 = file name
URL="https://docs.google.com/uc?export=download&id=$1"
wget --load-cookies /tmp/cookies.txt "https://docs.google.com/uc?export=download&confirm=$(wget --quiet --save-cookies /tmp/cookies.txt --keep-session-cookies --no-check-certificate $URL -O- | sed -rn 's/.*confirm=([0-9A-Za-z_]+).*/\1\n/p')&id=$1" -O $2 && rm -rf /tmp/cookies.txt
./nameofscript.sh googlefilenameid filename.deb
./nameofscript.sh 1F3JuZKFw6VIbZLDhjXiEdtD5uY792l0o pms.deb
Wait 10 sesc, and voila :slight_smile:
So I should upgrade kernel on linux server to get this working?
ahaha thanks :slight_smile:
Got it :slight_smile:
So I need to upgrade kernel and test this file
All the -11xxx CPUs need the 5.11 + kernels to be properly recognized.
Hardware transcoding and Hardware tonemapping require Intel Compute Runtime.
You’re on the bleeding edge. Did you bring :adhesive_bandage: ?
@ChuckPa
Hahaha you´re funny. OK kernel upgraded
5.11.13-051113-generic
You package:
plex@plexserver:~/Downloads$ sudo dpkg -i plexmediaserver.deb
dpkg: warning: downgrading plexmediaserver from 1.22.2.4282-a97b03fad to 1.22.0.4163-d8c4875dd
(Reading database … 113048 files and directories currently installed.)
Preparing to unpack plexmediaserver.deb …
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.22.0.4163-d8c4875dd) over (1.22.2.4282-a97b03fad) …
Setting up plexmediaserver (1.22.0.4163-d8c4875dd) …
PlexMediaServer install: PlexMediaServer-1.22.0.4163-d8c4875dd - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Intel QSV Hardware: Found
PlexMediaServer install: Nvidia GPU card: Not Found
/var/lib/dpkg/info/plexmediaserver.postinst: 298: [: Illegal number: ntel()
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: PlexMediaServer-1.22.0.4163-d8c4875dd - Installation successful. Errors: 0, Warnings: 0
Processing triggers for libc-bin (2.31-0ubuntu9.2) …
Processing triggers for mime-support (3.64ubuntu1) …
plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2021-04-13 16:02:15 UTC; 6s ago
Process: 2932 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_APPLICATI>
Main PID: 2934 (Plex Media Serv)
Tasks: 133 (limit: 18641)
Memory: 361.9M
CGroup: /system.slice/plexmediaserver.service
├─2934 /usr/lib/plexmediaserver/Plex Media Server
├─2964 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-d8c4875dd/Framework.bundle/Contents/Resources/Versions/>
├─3013 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner>
├─3107 Plex Plug-in [org.musicbrainz.agents.music] /usr/lib/plexmediaserver/Resources/Plug-ins-d8c4875dd/Framework.bundle/Contents/Resources>
├─3231 Plex Plug-in [tv.plex.agents.movie] /usr/lib/plexmediaserver/Resources/Plug-ins-d8c4875dd/Framework.bundle/Contents/Resources/Version>
├─3235 Plex Plug-in [tv.plex.agents.music] /usr/lib/plexmediaserver/Resources/Plug-ins-d8c4875dd/Framework.bundle/Contents/Resources/Version>
├─3240 Plex Plug-in [tv.plex.agents.series] /usr/lib/plexmediaserver/Resources/Plug-ins-d8c4875dd/Framework.bundle/Contents/Resources/Versio>
├─3282 Plex Plug-in [com.plexapp.agents.thetvdb] /usr/lib/plexmediaserver/Resources/Plug-ins-d8c4875dd/Framework.bundle/Contents/Resources/V>
└─3378 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-d8c4875dd/Framework.bundle/Contents/Resources/Vers>
Apr 13 16:02:15 plexserver systemd[1]: Starting Plex Media Server…
Apr 13 16:02:15 plexserver systemd[1]: Started Plex Media Server.
Server is running with hw transcoding now:
Imagine that :stuck_out_tongue: LOLOLOL
I will look at this: /var/lib/dpkg/info/plexmediaserver.postinst: 298: [: Illegal number: ntel()
I have no idea where/why that would pop up after months of no changes.
hehe :slight_smile: :slight_smile:
Ok what I just tried now.
Your uploaded version - Works with hw transcoding.
The updated available version 1.22.2.4282 makes the server crash.
Just an FYI -
I’ve had no issues with kernels up 5.11.11
I haven’t tried 5.11.13 yet, but several friends have, and they didn’t like
Caused lots of issues
Hi :slight_smile:
Im running 5.11.13 and Chucks upload works , but running a never version of Plex - kills plex instantly with a crash.
Server is currently running , indexing ans streaming, so for now… crossing my fingers. But im a bit worried to upgrade later on.
@ChuckPa whats the difference between your version vs the newer online version ?
Hw transcoding on the new version is crashing for me. :slight_smile:
@ChuckPa your version crashed tonight :confused:
Still unstable . Just disabled hw transcoding for now .
So it IS the kernel.
That failing matches the reports about 5.11.13
5.11.11 – at most
OR
wait.
Need any more :adhesive_bandage: ?
I need all that you can spare .
So if I should stay safe - what to do? I can spare the hw transcoding for now . Its powerfull enough to grind if needed :slight_smile:
Should I just go with the standard kernel 5.4 for now ?
