Server Version#: 1.32.6.7557
Player Version#: 4.108.0 - Plex Web
Tuner Make/Model: HDHomeRun Flex-4k
Guide/Lineup name: Error
Using XMLTV?: No
Channel number/Name: N/A
Whenever I attempt to add my hdhomerun tuner, it gets stuck on the step where it locates antenna EPG data for zip code 15090. Server logs attached.
Plex Media Server Logs_2023-10-24_05-24-56.zip (1011.7 KB)
Logs show it did find a guide but I see a websocket error afterwards.
Looks like you are on docker. Is your docker using host networking? if not can you try enabling that.
( as a side note your logs also indicate you have some database corruption when it is trying to save the credit detection)
Thank you for the reply. After putzing around with it tonight, I discovered the following:
Some Success
- I was accessing my server via a custom domain https://plex.mycustomdomain.com (not my actual domain). When accessed in that manor, I saw the behavior I described.
- If accessing the server via https://app.plex.tv, I was able to setup the tuner (with guide data) successfully
But Another issue
When attempting to record something from the EPG guide (which does load successfully now), I see the following. I’ve attached logs for this too.
This happens regardless of which URL I use to access the server.
Plex Media Server Logs_2023-10-26_20-36-50.zip (2.8 MB)
Database corruption
Do you have any suggestions on handling this type of thing? Should I delete/re-create it?
Some other notes from trying the host networking setup
I tried enabling host networking, but when I do I’m not able to see the container at all:
curl http://localhost:32400
curl: (7) Failed to connect to localhost port 32400 after 4 ms: Couldn't connect to server
The container shows as healthy in docker with the following logs
* Executing task: docker logs --tail 1000 -f <redacted>
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 40-plex-first-run: executing...
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing...
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing...
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Critical: libusb_init failed
Here is the docker compose I’m using currently (since the host networking didn’t pan out)
version: '3.2'
services:
plex:
restart: always
image: plexinc/pms-docker:latest
pull_policy: always
ports:
- 32400:32400/tcp
- 8324:8324/tcp
- 32469:32469/tcp
- 1900:1900/udp
- 32410:32410/udp
- 32412:32412/udp
- 32413:32413/udp
- 32414:32414/udp
environment:
HOSTNAME: "WikiK8s"
TZ: "America/New_York"
PLEX_CLAIM: "redacted"
PLEX_UID: 501
PLEX_GID: 20
volumes:
- /Volumes/USBSSD/plex/config:/config
- /Volumes/USBSSD/plex/transcode/:/transcode
- /Volumes/USBSSD/plex/data/:/data
- /Volumes/Media/:/media
