Correct, cast was not complete only one Cast member( Karl Urban). I particularly prefer mkv files with my system, as it works with my clients without issue.
any reason why “Fix Match” is not even an option for me on this show? I can’t even attempt to start fixing this issue right now.
Fix Match is only available to shows that are matched. If the series is not matched then you will get “Match” option.
And you must match at the top level of the show. Do not drill into the series.
…and that was it. I chose (from the top level) fix match->search options->Agent->the movie database->the boys 2019 and then it worked.
Some times you have to spoon feed them.
And Plex.
