Unable to open trailer@ ATV after changing router.
Hello pros,
Newbie here having trouble unable to  connect to ATV3 6.0 after changing the router.
I had my Plex working on ATV for several weeks, but as soon as I changed the router,
infinite loop on trailer occured.
(*When I had trouble with the same problem, I fixed the problem by installing certificate into ATV, I've deleted and reinstalled, but still doesnt work).
my log is as following:
21:34:58 PlexConnect: ***
21:34:58 PlexConnect: PlexConnect
21:34:58 PlexConnect: Press CTRL-C to shut down.
21:34:58 PlexConnect: started: 21:34:58
21:34:58 PlexConnect: IP_self: 192.168.1.64
21:34:59 DNSServer: started: 21:34:59
21:34:59 DNSServer: ***
21:34:59 DNSServer: DNSServer: Serving DNS on 192.168.1.64 port 53.
21:34:59 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.
168.1.64
21:34:59 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
21:34:59 DNSServer: forward other to higher level DNS: 8.8.8.8
21:34:59 WebServer: started: 21:34:59
21:34:59 WebServer: ***
21:34:59 WebServer: WebServer: Serving HTTP on 192.168.1.64 port 80.
21:34:59 PlexAPI: ***
21:34:59 PlexAPI: looking up Plex Media Server
21:34:59 WebServer: WebServer: Serving HTTPS on 192.168.1.64 port 443.
21:35:00 PlexAPI: servers discovered: 1
21:35:00 XMLConverter: PlexGDM - PMS: 192.168.1.64:32400
21:36:13 DNSServer: DNS request received!
21:36:13 DNSServer: Source: ('192.168.1.66', 57567)
21:36:13 DNSServer: Domain: trailers.apple.com
21:36:13 DNSServer: ***intercept request
21:36:13 DNSServer: -> DNS response: 192.168.1.64
Here is what I've done so far,
1. Re-install everything,
2. Deleted the current certificate, reinstalled it.
3. Reinstalled ATV certificate
Please give me any advice on this, Ive gone through the forum and cannot find anyone complaining about this problem after changing router.
(*Recently changed the router, and got a new cable,jackpoint because I've gone from ADSL to VDSL)
Thank you!
Sorry, I had to make it clear, what i meant by trailer is I cannot log into Plex*.
When you changed your router your IP addresses have probably changed.
