Unavailable Media
Server Version#: 1.16.0.1226
Player Version#: Web
Hello,
sinse I enable homes in my synology DS416play Plex show all the categorie but if I try to play a movie all are unavailable. I rellay don’t know how to solve this situation. I tried to apply read and write permission at my accont related Plex folder but witout success. Any suggestion?
thanks in advance
Have you checked out this post about some recent changes on Synology’s side requiring a different handling of permissions in Plex?
Thank you so much. it was unknown from my side…
Hi Tom80H, do you know even if the new Plex update has impacted the auto detect library change? because when i add new file on the folder strucutre Plex is not able to recognize them. I need to update the library manually. Thanks in advance…
Plex Media Server Logs_2019-06-19_10-27-56.zip (2.7 MB) here the log you asked. Hope it can help…
actually I just set only read permission. is it not enouth?
I would like to avoid to use ssh/putty command…
