Unreliable connection via remote connection on Synology 918+
Server Version#: 1.18.4.2171
Player Version#: multiple - plex web 4.12…3 (but it’s not a player issue) - this is a message on the server UI
I simply cannot maintain a reliable/consistent remote access connection.
No matter what I try I get a connection for a few seconds (via the Plex web app) and then I get the [server] is not available outside your network. Sometimes it’s 5 seconds, sometimes not at all - sometimes it’s up for a few hours - I just can’t pin it down.
I am using a Synology NAS 918+ to run Plex server, connected behind BT router to the internet.
I have completely disabled my VPN but it’s not that.
Lost - which log files would be useful?
Thanks in advance,
Lee
It gets worse.
Hunting around the (awful) support pages I found a note about the secure settings - which appeared correctly set to preferred - as a test I thought I would set this to enabled (it was preferred) - didn’t help.
Then I uninstalled Plex from my NAS hoping to find some magic cure and have since reinstalled it - only to find that I can’t connect to the service AT ALL .
ie : internal ip:32400 is not where the service is any longer?
I can see the Plex processes running on the NAS - and of course we cannot change the default port - so what is the problem?
No point paying if this doesn’t work eh?
Any ideas?
Thanks,
Lee
When you uninstalled, what did you do?
a. Uninstalled only the package?
b. Deleted the Plex share?
c. Deleted user Plex?
-a
It seems to have resolved itself - the version now on the server is now 1.16x and when I browse to the Plex UI it “advises” me there is an update - so a mental note from me, in future I only update via the Synology package center :joy:
The jury is still out on the connection stability - I’ve set up a port rule rather than rely on uPnP - will update the thread later
