Server Version#:1.28.1.6104
Player Version#:Web app on Server
I followed the procedure to save my libraries, etc into a tar file. then deleted my linux partition and reloaded Bullseye. I then put my libraries back. My movies are there and they play, but my trailers don’t play on the server or on tv. On server it just cycles like it is loading. Player setting somewhere in server? Server has a reserved IP and is networked over ethernet, not wifi. Everything else appears to be ok.
Plex Media Server Logs_2022-08-25_12-54-04.zip (872.5 KB)
Color me embarassed. Debian setup got the timezone correct, but the time was 5 hrs off??? Set up NTP and now the time is correct and they play.
Edit Well, thought it was fixed. Debian kept changing the bios RTC. Confusing since I am -7 UTC and it was 5 hrs off. Did a timedatectl set-local-rtc 1 --adjust-system-clock and now the time seems to match (It’s a dual boot machine with Windows 10) with windows and bios. Trailers not working thought the time is correct?
On my TV (ver 7.0.13.7804-2fd4cda44-Plex) Says “Playback stopped due to multiple playback errors. Check your connection and try again” Network connection is fine.
Plex Media Server Logs_2022-08-28_14-50-02.zip (365.8 KB)
This is latest logs.
