I would like to upgrade my Synology 718+ to DSM 7, and read the thread here.
I might be misunderstanding the doc but it looks like the new PlexMediaServer user requires read/write on all shares?
That seems risky from a data integrity standpoint. I don’t want to grant a service account write access to my shares. Is there an alternative configuration?
You cannot continue to grant user Plex permission to read the shared folders in DSM 7 because user Plex is no longer used (mandated changes for DSM 7).
Please read here and understand all the changes which were required then read the supplement (packaging - structure change which gives us as close to DSM 6 as was possible to do in the new DSM 7 platform environment)
I read those articles and linked to the first in my original post. The question is can the new PlexMediaServer user be granted read-only to media shares, or is it absolutely required to grant write access?
I suppose it’s the same as on other platforms.
If you give Plex only read access, Plex will e.g. not be able to create optimized versions for you. Otherwise Plex isn’t writing much in your media folders.
That’s good news. Should this bullet be updated in the instructions? It explicitly states read/write.
“4. For each share that you wish Plex Media Server to access, you need to go and set read/write permissions for the PlexMediaServer system internal user.”
