Server Version#: 1.40.3.8555
Player Version#: 4.131.1
PMS is run on a Windows 10 Pro system.
I recently switched internet providers from one that provided a modem/router combo to one that provides only a modem and I where was responsible for purchasing my own router.
Since that time, 3 out of the 10 regular users now connect with an indirect connection while others will be connected at the same time with a direct connection, and I’m unsure of why that is.
My private IP in the port forwarding entry on my router matches the one entered in Plex, and while at least 7 other users are connecting directly when streaming, these other 3 users who all used to connect directly prior to me switching internet providers and adding a router now only connect indirectly.
I can’t think of anything on my end further to look at in regard to what might be causing the issue since most of the people connect directly perfectly fine, so could this be something on the end of those connecting indirectly and if so, what might that issue be?
