we’ll see if it’s all still working in an hour…
Mine failed overnight, BTW.
I had to reboot my Plexiverse to get it back up.
That’s happened a few times since Skip Intro came to town.
If I have an overnight HandBrake Fest going when Scheduled Maintenance kicks in - it bears watching - and I was asleep…
The ‘restart sequence’ did the trick, but if that fails Fordy had better show up in body armor… I WILL be unpleasant… lol
If you enabled https, try https://192.168.1.1:8443/Main_Login.asp
Advanced Settings → Administration → System tab → Local Access Config
Also:
http://router.asus.com/Main_Login.asp
or
http://192.168.1.1/Main_Login.asp
amazing!!
thanks
I happen to have the AC68U.
The /Main_Login.asp part is key. You get a “no response” if you don’t use it. I have a shortcut on my bookmark bar. Too much of a pain to remember otherwise.
I happen to have one of those as well - and don’t recall doing anything special with htpps - but the bookmark I set to the local address above has been working for - ever.
Good catch. I run Plex on a Synology NAS. Didn’t know about that setting in Windows. I’ll file that one away for the future.
Same here. ![]()
