Various Apple tv beta library glitches 7.9 (21935)
Mark a TV episode played/unplayed or even watch something to completion.
Come out of that TV series to library.
Library auto scrolls to top of screen itself.
Movies
Scroll down through your library too fast.
It’ll jump back to top of library itself.
App loading.
If you come back to Plex after a while. It sits there. Doesn’t refresh itself and then hangs on spinning wheel.
The auto scroll problem continues to happen outside the beta version and it’s highly annoying.
Yes, this just happened. I had something on pause, it would not resume. no buttons would respond except for the TV button. It’s happened a few times. I usually reboot and it’s OK.
The thing that bothers me, unrelated to any of the above, is that after the Library Agents were updated, my TV shows would reach into my Movies folder and add some related movie to some TV episodes, so that PLEX showed the number 2 on those items, indicating more than one source.
Example: I have the series Farscape loaded into my TV Library, and the two Made for TV movies in my Movies library. After the Agent update, it took those two movies (The Peacekeeper Wars" and loaded them into Season 1 Episodes 1 and 2. Nothing I could do would fix it. This happened to other TV shows that also have Movies, Babylon 5, Star Trek, etc. Perry Mason, it loaded all 36 or so TV Movies into the Series, into Season 1. I had to load “The Movie Database” into my TV show agents and then choose that as the main agent, then it reverted to normal. In my Movies Db, I was able to choose “Legacy” and that fixed it there.
