Video Freezes but Audio Continues
Hello, looking for any kind of help. I have a rpi3 connected to an external drive which I use for all kind of network media storage and I also run plex on it. Recently, with this one certain show I have downloaded to the drive, it does not play correctly on the fire tv (pendant version). The video freezes after playing for a split second and then the audio continues. Plays fine on all other devices. There is no transcoding, all direct play. And I believe it had worked before briefly as well. No idea why it started doing this. And it is also not a network error the speeds are fine and I had thought maybe the bitrate was too high but it’s nothing special. Checked the logs as well and no errors showed up any time I reproduced the issue. First post so if any other info is needed that I’m not aware of just ask. Oh and plex client version on fire TV is 7.9.0.8439, and the rpi plex server is fully up to date. Thanks. Oh and the show uses HEVC in .mkv and AAC audio.
