Video loads but does not play
Plex Server version
1.41.4.9463
Macos version
15.3.1 24D70
ATV version
18.3 22k557
Plex app version
8.45(9684)
Homepod version
MQHW2LL/A
18.3 (22K557)
MQHW2LL/A
18.3 (22K557)
When playing just about any show or movie the video loads into the app but does not start playing. I have to press pause and then play ti get the video to start streaming.
This has been going on since i bought the new Apple TV and installed the plex app.
2/20 10:28 am pacific it did it
Navigate to the desired show.
Select show
Show loads as if it is going to play. the show seems pauses
Use remote to press pause
Plex Media Server Logs_2025-02-20_10-35-52.zip (805.4 KB)
Use remote to press play
The show starts playing.
let me know if you need any further logs or to duplicate any issues
Same issue for a while now. Havent found a fix.
Same here, now mid March and no info or remedy
Just started having this problem too. It started after adding my second HomePod and putting in a stereo pair. Not sure if it is related or a coincidence. I will start a TV series to play and all is fine. It will start the first episode fine will play the credits and count down to the next episode OK. Plex will then start the next episode but then stop at 00:00 and will not go any further until the play/pause button is pressed. Plex will then do this on all subsequent episodes.
Included is a log where his is duplicated. The play/pause to continue to play next episode on 4/20 11:20am PDT.
Plex Server
Version 4.145.1
OS
Ubuntu 24.04.2 LTS
Apple TV
Model A2843 (128GB)
tvOS 18.4.1 [22L261]
Plex App
Version 8.45(1)
Homepods
Model MDEW4ll/A
Version 18.4.1 (22L261)
Model MQJ73LL/A
Plex Media Server Logs_2025-04-20_11-35-15.zip (3.5 MB)
I have been having the same problem as well as some movies having audio drop out. This post seems to have solved both issues for me - seems to me it’s to do with the Homepod audio output as opposed to using TV speakers.
Enable “use old audio engine” in the Plex App settings on the ATV and see how you go.
