Many of my tv shows have covert artwork that was placed into them with iTunes originally. The problem is that Plex displays a repeat of the same cover art on every episode, which looks dumb in the Plex world.
Anyone know of a utility that will load up a folder of video files and quietly strip out the embedded cover art? Manually loading them into iTunes then deleting the art one at a time is tiring!
The following will solve your issue, together with the one you reported here:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
If you are using Filebot, please use the right renaming schema for Plex, not the default one.
Give your Season folders 2-digit numbers, e.g. Season 03
Afterwards, perform the Plex Dance with the whole show.
