WCW Thunder Not Scanning All Episodes
Server Version#: 1.26.2.5797 | linuxserver/plex
Player Version#: 4.76.1
I cannot get all of the TV Show “WCW Thunder” to be properly recognized. Only the first 12 of 156 episodes are recognized, despite the exact same file naming structure for all files. This does NOT appear to be an issue related to file naming.
According to the logs, Plex is seeing all 156 episodes.
Skipping over directory 'WCW Thunder', as nothing has changed; removing 156 media items from map.
I have tried changing filenames, using the 100% “proper” file naming structure, doing the “Plex Dance” over and over, etc… as far as I can tell this appears to be an issue that is not on my end. I recall a similar issue with the ECW TV Show where I had to wait for someone on TVDB end to fix the issue. Could someone please look into this? Thanks.
Can you provide exact file names for episodes that are not scanning, and a copy of the server logs after a plex dance scan? Do you have the prefer embedded metadata enabled?
