What to do when even the Plex Dance doesn't work?
I had a mess up when adding the two-part documentary ‘History of The Eagles’: I had two versions of it and I accidentally added the one I wanted to delete.
I scanned it, Plex found it and added it without any problem. Then I deleted it and added the ‘proper’ one I wanted to have in my library but now when scanning again, it doesn’t find it!?
I tried the Plex Dance, didn’t help so…what else can I do to fix this?
Thx in advance!
That’s a tv show. Are you trying to add it into a library of the type “TV Shows”?
And if so, how are the files named?
Sorry, my bad! I hadn’t done the proper renaming on the second copy of the the documentary. Renamed, rescanned…all good! :slightly_smiling_face:
