What version Plex for DS1821+ with Ryzen CPU?
I have the new Ryzen CPU synology NAS and i cant get the PLEX app to work on it from the store. It keep saying unable to start app. Does anyone that have these new versions , Series 21 of synology NAS know what version of plex runs on it?
Try the Intel 64-bit version from plex.tv/download.
See installation guide for details on performing a manual installation:
Installation & Setup of Plex Media Server on Synology
Synology FAQ (DSM 5 & 6) - Questions, Answers, and a few How-To’s
So i tried that version of the Plex server and i got the same error even though i followed the steps
DSM 6 or 7 please?
If still DSM 6,
Give yourself (Control Panel - Shared Folder) R/W access to the Plex share.
Open Filestation, navigate into Library until you see Logs.
Right-click Logs and ‘Compress to Logs.zip’
attach that zip file here please
good. as i expected. continue as directed please
search for that file and couldn’t find it. I use step recorder to show the steps i took, please view the steps i took thank you.
I’m sorry, I cannot play that file.
Here, I threw this together. Perhaps it will help?
Not sure how to play that file.
Here is what you should see in File Station. Compress the Logs folder and attach the zip file to this thread.
i dont have that much folders. its a fresh installment that wont run
Suggestion: Since this is a new installation, so no history, etc to save, completely remove Plex Media Server from the system, reboot the NAS, then start from scratch with a manual installation using the latest version downloaded from Plex.
FAQ 9: Uninstalling PMS - Completely start over
  1. Package Center - Remove the Plex package
  2. Control Panel → Users - Delete user Plex
  3. Control Panel → Shared Folders - Delete the Plex share
  4. Restart DSM
If there are still issues installing on the Ryzen,
Please call out to me. (@ChuckPa)
We will arrange to go deep diving and find out the issue so I can correct it
Hello @ChuckPa I have tried several suggestions and I keep getting the same error.
I have the DS1621+ which has the same CPU and no issues with Plex, though since installing I have now upgraded to DSM7 and still works perfectly.
Do you use the version in the Synology store are the one on plex.tv download? if so what version?
I use the plex.tv download as the one from Synology is not being maintained until DSM7 is released and is a very old version. I use the Intel 64-bit package from the downloads section
@HomeMediaServer2018 How many local streams and remote streams does your Synology handles?
@CGameDev I only use about two local streams and one to two remote streams at once and it copes perfectly, much better than my old DS918+ (which had hardware encoding). It leaves my old DS918+ for dust in regards performance
@HomeMediaServer2018 Is the software transcoding really good, because i know it does not have a gpu built in, and does adding the NVME cache drives make a significant difference?
