@BigWheel said:
if you have not rearranged things. click “more” on the bottom and then LiveTV & DVR
Your suggestion works only on the Android Mobile plex app (not the Android TV app), and it doesn’t work properly for me.
Android Mobile behaviour:
Version 7.0.35502
I have 2 Plex servers; one is on my Qnap (it’s a backup server), the other is Plex server in windows running in a VM (primary). When I do as you suggested on my phone, it will only give me LiveTV menu options for QNAP, not the Windows Plex server.
Android TV behaviour:
Version 7.0.2.5441 (1e95bf1b)
Version 7.0.3.5502 (4c9e7618)
If I connect from my Mi Boxes (I have 3) none of them see Live TV menu options on the left menu, regardless on which Plex server I connect to. However, if I switch between both servers, I see the Live TV appear in the menu on the left, then disappears quickly.
What’s questionable is that I tried to switch servers, back and forth between the 2, about 4 times, the last time I logged into the QNAP server, the LiveTV/Record menu options stayed on the left menu bar, was able to use them, but they disappeared in about 4 minutes.
If I log in to the Windows Plex media player, I see the Live TV section (with the two Recording Schedule and Program Guide options), on both Plex servers.
This points to an issue with the Plex Android TV app - I am going to find older versions and see if downgrading will fix the issue.
Fire TV behaviour:
Version: 6.15.2.4143 (9459e30a)
I don’t have this issue with the Plex app:
I uninstalled Plex app on my Mi Box, extracted the Fire TV Plex app version, installed it on the Mi Box - Live TV behaviour is back to normal. Looks like the new versions break this functionality. Great dev work Plex…
