Is the lock ever going to be fixed to lock a field?!
Every time I add a file the current row and the last two full rows lose their names to the system even when locked!
Plex%2002|690x371
Same thing itâs happening to me and itâs annoying.
Just added one episode and I wrote the title for that specific episode (since it canât find a title for my language: spanish) and pressed the lock button. No tabs changed, lock icon turned orange, saved and apparently it stayed like that.
Now I added another episode, and the title for the previous episode was erased, but the lock stayed there:
Itâs like: ok, I know that you want this field locked, but I donât really care about what you want.
If you want items to stay locked they have to either be matched, or changed to the Personal Media Agent - then hand edited.
If you are using MP4/M4V files with Local Media Assets in the top slot - and there are embedded and bogus Title Fields within - Plex is borking your match in favor of those bogus embedded titles. Do this:
Under ALL tabs in Shows and Movies grab LMA and drop it at the bottom of the stack of active agents. Red: where it was. Green: where it goes. Then refresh metadata, Fix Match, or change to Personal Media and hand edit.
If your items are never matched, or have embedded tags that are constantly causing the item to be âunmatchedâ -youâll never, in a million years, get Plex to lock a field with that little padlock thingy. It simply wonât work.
Stop lookups with the Personal Media Agent, or fix your files so they stop coming unglued from the match they got on the very next scan.
Why the âlittle padlock thingyâ works for everything but the title if it âwonât lock a field in a million yearsâ? It just doesnât make sense
If âThe Titleâ is the thing that wonât stay lockedâŚ:
Take Local Media Assets out of priority, as described above - or get used to a never ending Title Change.
or
Stop using MP4/M4V files 'cause those are the ONLY files Plex reads Title Fields in and with LMA in priority Plex will prefer a bogus embedded Title over a perfect file name. Many times, due to this - the match comes unglued and all those padlocks are nothing more than pretty icons.
Then this is in fact, a bug. There is no way that is expected behaviour.
Well, that assessment would be correct - and for years Plex has thought they squashed it - only to find out⌠itâs back!
Plex is convinced (in error) LMAâs default position should be in priority - ruining the experience for every Plex person on Planet Earth that uses MP4/M4V files.
If you donât name your files so they can be matched, or stop match lookups, every time Plex goes looking for that match it doesnât have - all your edits go up in smoke.
Plex Veterans know this already. We know how to stop it and try to pass that on to you. Weâre successful sometimes - sometimes not.
Converted one of them to mkv, and it still erases the title.
Until you Plex Dance that item - nothing will ever change.
You have a bogus bundle that you need to re-do. <âanother thing Plex canât seem to do is re-write a bogus bundle with a new one by clicking âRefresh Metadataâ, requiring the oldest Plex Work-Around - The Plex Dance:
ALL steps in the exact and precise order described, or it simply wonât work. You should also be aware - if you donât name your files so they can be instantly matched - this problem will NEVER go away. The correct time to fix that - is halfway through The Plex Dance - while the item(s) are not where Plex can see them - so when Plex does see them - theyâre perfect.
Did The Plex Dance, changing the name to S03E02.mkv halfway through, added, still doesnât get a match and still erases the title if I set it manually.
So thatâs your episode name?
Really?
This seems appropriate ATM:
https://support.plex.tv/articles/categories/your-media/
If your files were named so they can be matched - and you have LMA out of priority (or are using MKV files) - and have completely REMOVED the Show (yes, the whole thing) while undergoing a Plex Dance - you wouldnât be having this problem. You canât fix one file - while every other file is still borked.
When the bundle is borked - the only thing thatâll unbork it is a complete Re-Do. Plex Dance or not - itâs up to you. Follow the instructions for Media Preparation or not - itâs up to you.
We Veterans donât have this problem. We did once, but we found the cure:
Yep, thatâs the name and that should be enough, since that part is the only thing that is going to be matched against the agent. Never had a problem naming it like that, or adding all the bells and whistles.
Iâm not gonna remove the whole show since there are like 1.1K+ episodes, and I have made some manual fixes here and there, and I donât feel like going through all of that all over again, I canât even remember what I did.
I guess I will have to wait for a proper/real fix and keep copying the âSorting Titleâ to the title every time I add a new episode.
Thanks anyway.
Well, OK.
I can lead a horse to water, wrestle it to the ground and drown it in 6 inches of of the stuff, but I canât make it drinkâŚ
Note: Users have been waiting for this âFixâ you speak of for about 15 years. Should be any day now (FileBot, The Plex Dance and The LMA Hack are more of an âInstant Gratificationâ thing).
Merry Christmas
Because maybe the horse is hungry and not thirsty ![]()
Merry Christmas!
Hereâs a distraction and a Christmas Eve Story (in a few hours):
I lived on Hatteras Island for - my youth - Surf Fishing, working like a dog in Summer, and trying to rid the world of Adult Beverages (generally an epic fail - thereâs more of that stuff than you think).
Anyway, a big âTouronâ Draw was riding horses from the stable out to âThe Pointâ, a spit of sand formed at the end of the âLabrador Currentâ from the North and âThe Gulf Streamâ from the South. âThe Graveyard Of The Atlanticâ, as itâs so appropriately named.
Sometimes, after a storm in hard Summer (when itâs too hot to do anything and the fishing generally sucks) pools form after high tide. Some of these pools can be ankle deep, some, can swallow a Suburban - Whole.
The horses are very familiar with their surroundings, have been doing their thing for a long time, are gentle beasts that can be trusted to bring everyone home should âthe driversâ get lost in 90 minutes when their âshiftâ is over.
Itâs hotter than blazes. Spanish Mackerel are running hard and a good cast or 6 will make dinner, so weâre all there after work when a pack of âTouronsâ show up horseback to check out The Point.
âHereâs one of those pools that would be nice for the horses to wade through, Honey. Letâs go.â
The Horses, stopped for a moment, knowing what was going to happen, and even looked back at their charges as if to say: âAre you sure?â, but at the insistence of their drivers, took a little leap into what was certainly a âPuddleâ 14 feet deep - the same one they pulled a Suburban out of earlier that week, riders screaming and swimming, tupperware, water bottles and sandwich bags afloat with floundering âTouronsâ, the majestic horses (this must be how they have fun) now all cooled off swam to the opposite bank and stood waiting for everybody to swim to safetyâŚ
Horses are so coolâŚ
Normally, this is what happens in Summer (when ur Mackerel Rig is suddenly inadequate), but those âDistractionsâ are entertaining:
âLolaâ landed that beast with some instruction and it was cleanly released - Jack Cravalle - about 30 pounds - in 12 minutes - at 8 minutes âLolaâ was informed: âLand it, or weâre cuttinâ it off!â - She landed it - I had tied her knots - I knew it was possible - 12# FireLine with an Assie Braid to 30# shock for the 5 ounce Stinger toss - that I threw right on top that pack of feeding Jacks - and handed her rig to her, fully involved with line peeling off on 10# of drag. A 10â- 9" graphite one-piece with an ABU 6500 High-Speed Custom Reel. A sweet rig.
