Hello everyone,
i have some issues with music premium library.
For an unknow reason, gracenote information are not used by plex.
As you can see
Do you know why ?
(embedded tag uncheck )
Settings - Server - Agents - Albums - Premium Music
the line ‘Plex Premium Music’ must be in the top position
Of course I already check that parameter.
Plex premium is top position for album and artiste
Was it already in this place when you added the album into Plex for the first time?
Because Plex won’t change the track names when the agent configuration is switched after that.
You will have to make it so, that Plex will “think” it sees this album for the first time.
The Plex Dance (with music, you can omit step 4)
But on a different note: You might want to use some meta tagging software to embed the proper meta data into your files. It does not only help with Plex but also any other media player software.
Ok thanks you I will try tomorrow.
Lets plex dance
Hello again.
I tried and it doesn’t work : (
I even tried to remove my library/ clean /purge / re-add my music library but no luck.
EDIT : when i fix the match, album name and year change but not track’s name …
