s01e05 episode has the same name as s01e04 in German.
The description differs but the name is the same " Hathi und die kleine Elefantin"
but it should be “Überbüffelt”
My media episode ordering is TVDB
also in s02e02 there is the same name and descriptions as in s02e03. It duplicates the metadata on the wrong episode.
Which one?
There are several on TheTVDB, depending on the actual show.
Are your files in MP4 format? If they are, clear the checkbox “Prefer local metadata” in the properties of the library, on the Advanced tab.
Then Refresh Metadata of the show.
There were wrong and missing links from the episodes on TMDB to those on TVDB.
I’ve corrected the wrong ones and and filled out the rest.
This may take 3 days until it makes its way into the Plex proxy.
So, wait a week, then Refresh Metadata of the whole show.
