Hi, Any help on the following would be much appreciated.
I have Plex Server Running on a server on my home network.
I have two kids with xbox 360’s in there rooms that would like to access the plex server.
I have created free plex accounts for them and given them access to the server.
All devices are connected via ethernet in the house.
When I load Plex on the xbox I either get the PIN or manual login (Email and pass). This all works fine and login works and they can see all the media.
When we go to push play, all I get is the spinning loading thingy and eventually get the error message “There was an error communicating with your Plex Media Server. Make sure it’s turned on and accessible and try again”
If I sign in to there accounts in a browser (on a pc) I can watch from there no problem.
In restrictions: Iv allowed channels and sync.
On my master plex acc… remote access is setup and working…
(If i login on my account on there xbox, it works perfectly, I only get this issue when using the shared accounts)
But as you all know i cant use my login on all devices as I get the login every time.
Thanks in advance,
Damien
