xbox app issue with loading anything
I am having issues with the Xbox One app and only the Xbox one app. I have read and tried other peoples posts without anything helping.
Background: Latest Xbox Plex app, Latest Plex server on the local network, works for others off the network (on a different device), and on the network with other devices. I have changed the setting to allow unsecured connections in the app and opened up the Plex server on the Local PC as much as possible.
Upon install of new plex app, it connects and displays the empty screen with prompts, it shows my media libraries and my server name. I can access movies, Some play without issues…some don’t play. Once the plex app on the Xbox is closed and reopened. I cannot see my server at all under libraries and acts like there isn’t anything found. Under “settings - Media server” it shows mine as nearby and green. but there is forever a loading sign on the blank screen, and nothing ever loads into the libraries.
The only way to get connected again is to uninstall and reinstall plex app on Xbox.
Any ideas anyone? Super annoying!!
@phil823 Hi there. What server version are you running? Could you enable logging in the app and grab some server logs?
i am using the latest server version
Version 1.9.6.4429
and the latest xbox one app
how would you like me to share the .zip log files?
same. cant play ANYTHING. newest server version and app
I’m having troubles even loading 1080p/AAC stereo films. WTF?
still never got a reply…plex is still completely unusable to me with my xbox one…which is my main hardware for using plex…
I’m having this issue constantly as well.
Are your Xbox One’s connected via WiFi or ethernet? There are some known WiFI issues with the Xbox One that should be fixed in an upcoming OS update, so I suggest trying to connect your console via ethernet and see if that helps.
