Server Version#: 1.29.0.6244
Player Version#: Client 5.47.1, Platform 10.0.22621.2216
Plex Media Server Logs_2022-10-16_12-43-29.zip (4.3 MB)
Certain DVD based content that has been compressed via (MakeMKV > Handbrake) fails to play on XBox. I have not experienced this with movies or Blu Ray based content, only select DVD show episodes (ST Voyager, Hercules, etc.). I compress all episodes with the same settings, however not every episode from a show will exhibit this issue.
When an episode that will fail is selected for play, the TV screen will go blank and display a message that no signal is detected - as if the Media Server is not sending data, or perhaps the Client is not rendering? I can select “back” on the controller and wait a couple seconds (this is slower than hitting back from content that will play correctly) to return to the episode list.
If I play the same content on a PC Web client, the video plays as expected with no issues, leading me to believe the Server is working correctly, but the client lacks capabilities.
For reference, here is the data from MediaInfo (yes, glorious Hercules…). The default sub likely has no data, I generally default to “forced only” and “default” in case there are any.:
General
Unique ID : 175174610252032345741339049353293778102 (0x83C96719D7ADFF557EC4EFD4B27ACCB6)
Complete name : G:\general\Hercules The Legendary Journeys\season 01\Hercules The Legendary Journeys (1995) - s01e07 - Pride Comes Before a Brawl.mkv
Format : Matroska
Format version : Version 4
File size : 1 003 MiB
Duration : 44 min 20 s
Overall bit rate : 3 161 kb/s
Encoded date : UTC 2021-10-18 03:26:56
Writing application : HandBrake 1.2.2 2019022300
Writing library : Lavf58.20.100
ErrorDetectionType : Per level 1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings : CABAC / 13 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 13 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 708 pixels
Height : 478 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 157 r2935 545de2f
Encoding settings : cabac=1 / ref=13 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -21 ms
Title : Stereo
Language : English
Default : Yes
Forced : No
Text #1
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Language : English
Default : Yes
Forced : Yes
Text #2
Format : VobSub
Codec ID : S_VOBSUB
Duration : 43 min 10 s
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : :Chapter 1
00:06:43.270 : :Chapter 2
00:25:30.729 : :Chapter 3
00:31:49.708 : :Chapter 4
Any assistance is appreciated.
