XPlay (Android)
Hi are you still looking for tester ? i would like to test this on my Shield thanks.
Hi @DF_Cineplex,
Thank you for your interest to XPlay
Now there is no a separate test version.
The app is published on Google Play.
So if you would like to support the project you may install the app from the store and than share your opinion.
Link to the app: Get it on Google Play
Happy New Year!
I would wish all the best for you in next year!!! Be happy! :slight_smile: :tada::fireworks::christmas_tree:
Thanks for replying. i will take a look at the App and do some testing . will let you know what i think and where where improvements may be needed. have a nice day.
Hi! I have the lastest webOS on a LG TV. I just get a spinning red circle. Any updates on that issue?
Is it possible to just test the app without buying? Trial version or what ever
Hey Martin, this here is the Android App, not the webOS App, You have to ask here for webOS:
Hi @DironDir,
Something I noticed last night which I never noticed before, when watching a movie normally when the movie finishes I just hit the back key and go back to the home screen.
This time I left the movie until the very end, it stopped at the end and it did not return back to the home screen as it should or movies where ever you selected the movie from.
Since the app was published on Google play there is only one version for everyone.
Hi @Gordon-R,
It’s a bug. Will be fixed in next update.
Thank you.
Thank you.
I will look forward to hearing your opinion.
Thanks @DironDir and a Happy New Year :grinning:
Hola estoy muy interesado en su proyecto me gusta mucho la aplicacion ,me gustaria aportar mis experiencias y lo que considero se podria mejorar,desde mi ignorancia,un salu2.
Lo que me ocurre a mi con mi tvbox x96 mini es lo siguiente,con un proveedor que tengo solo me funciona en protocolo DASH,en HLS no me funciona y me trascodifica,hay alguna manera o configuracion para que no ocurra?,gracias un salu2.
Me gustaria saber si en los capitulos de las series se les podria habilitar la opcion de poder escoger reproducirlo en reproductor externo como en las peliculas y si al hacerlo trascodifica o si se usa la opcion Share no trascodifica.
Y otra duda porque a veces en la pelicula le doy a la opcion de reproductor externo y me sale que no se puede utilizar?gracias y disculpe me extienda tanto pero llevo tiempo tratando de configurar su aplicacion lo mejor posible para que no trascodifique y funcione lo mejor posible,agradeceria cualquier consejo en ese sentido muchisimas gracias y un salu2.
?? English would be nice ^^
Hello I am very interested in your project I really like the application, I would like to contribute my experiences and what could be improved, from my ignorance, a salu2.
What happens to me with my tvbox x96 mini is the following, with a provider that I have only works for me in the DASH protocol, in HLS it does not work and it transcodes me, is there any way or configuration that does not happen ?, Thanks .
I would like to know if in the chapters of the series they could be enabled the option of being able to choose in the external player as in the movies and at the moment of the transfer of the action. Share does not transcode.
And another doubt because sometimes in the movie I give the option of external player and I get that can not be used? Thank you and sorry I extend so much but I have been trying to configure your application as best as possible so that it does not transcode and work as best as possible, I would appreciate any advice in that sense many thanks and a greeting.
Hi!
In the app DASH and HLS - both are transcoding options. Because only the Plex Server can create a stream and it decides in which mode to start the stream. So it depends on many factors (movie container, codecs and so on).
Also I will check HLS mode. Looks like it doesn’t work sometimes. I need more tests.
I check it and if it possible I will add such an option. Originally it was made for testing purpose only.
I guess it strongly depends on what file is used (.avi, .mkv or what else)… And Android OS doesn’t know what app
Okay. I’ll check it and let you know
@DF_Cineplex,
I got the same result. Direct playing this movie without sound.
I could play this video only in transcoding mode with the plex app. Could you play in Direct Play mode with sound?
Anyway I need to look for more infos what could be done with it.
